Question How to fix CPU and DRAM LED failure?
Jan 1, 2020
5
Specs:
  • B450M Bazooka v2 Motherboard
  • 16GB (2x8) Corsair Vengeance RGB RAM
  • SU635 240GB ADATA SSD
  • Coolermaster MWE500 Bronze power supply
  • AMD Wraith Stealth CPU Cooler
  • 2TB Seagate HDD
  • Ryzen 2600 CPU
When i first finished building this PC, it would stay on until I turned it off. When I got nothing after hooking it up, (No POST, no BIOS, nothing), I went to see what was wrong and couldn't find out what was wrong, so I just hooked it back up.
NOW when I boot my PC, the motherboard's EZ Debug LEDs indicate that either the CPU and DRAM are not detected, or that they have failed. The PC then shuts itself off after 2-3 seconds and I have to unplug it and plug it back in to boot again only for the same result. This is my first time building a PC and I'm extremely confused as to how to proceed with this. Thanks!
and the cpu is? try 1 stick of ram only?
make and model of the psu?
It's a Ryzen 2600 CPU. The power supply is a Coolermaster MWE500 Bronze.
I took one ram stick out and upon booting only the CPU LED lit up, but it still shut itself off after 2-3 seconds. I then reinstalled the second stick of ram and the same thing happened, so I guess there's no longer an error with DRAM anymore? I don't know.
