so im having this problem that my ram speed is 2667mhz in task manager and 1366.7mhz in memory and in spd it shows 1798mhz in cpu z and i wonder if that is really my ram speed but in my bios it shows this
Overclock your ram manually.my mb is the asrock b550m steel legend and my cpu is 5600x
Nothing to fix,it's running at 2666MHz. It's DDR (Double Data Rate) some programs show base frequency which you have to multiply by 2 to get effective speed.so im having this problem that my ram speed is 2667mhz in task manager and 1366.7mhz in memory and in spd it shows 1798mhz in cpu z and i wonder if that is really my ram speed but in my bios it shows this![]()
i actually forgot to specify that my ram speed is suppose to be 3600mhz do i still dont have nothing to fix?Nothing to fix,it's running at 2666MHz. It's DDR (Double Data Rate) some programs show base frequency which you have to multiply by 2 to get effective speed.
im trying ti select it nut it isnt letting me it keeps coming back to that 2666mhz settingOn the last photo you can see 3600 select it in the bios.
i already enabled my xmp profile 1 but i dont know why the speed is still 2666mhzIf you don't enable XMP, apparently your RAM will default to 2666 Mhz. CPU-Z shows you have an XMP profile for 3600 Mhz. So enable XMP and confirm it's running at 3600 Mhz. Might have to set speed manually. Shouldn't be necessary though.
If 3600 Mhz doesn't work, it's either your motherboard or CPUs Integrated Memory Controller limiting you. If you are on newer Ryzen, 3000-series and up, it should work. Intel is so-so, depends on what they allow. Chipset of motherboard etc. Ignore the "Officially supoorted" stuff. Both AMD and Intel only "officially" support 3200 Mhz. Obviously that is not the limit.
yes i did enable xmp and it says on the memory tab 1333mhzWhat do you see in the memory tab in CPU-Z ?
Did you enable XMP profile 1 ?
my mb is the asrock b550m steel legend and my cpu is 5600xWgat are your MB and CPU, some are limited to certain speed ?
