Hello,
Recently after getting a new case I decided to use an old HDD as an extra drive, 500gb, which I have been using as an external one. It works completely fine, and I put it in, and the error screen comes up with the text: Smart failure predicted on hard disk drive, or close enough. I skipped the f1 error through bios and it works completely fine in windows after assigning a drive letter to it, however it always comes up with the error and goes away after 5 seconds, so it is quite annoying. Is there any fixes so it is 'not predicted'? Because the drive works very well. It is a laptop HDD fyi, Samsung hj500 if i remember correctly. Thanks!
