[SOLVED] How to get most out of my current build?
Mar 3, 2019
6
This is my current build:
Intel core i5-6402p
HIS R9 290
HyperX Fury 1x8GB DDR4 @2133MHz
Asus H110M-C
Cooler master GX650
Antec NX200
What tweaks do you suggest to make the most out of it?
I run this on LG 22inch AMD Freesync FHD monitor.
Hello again,
Well, its kinda a big tweaktown.
Firstly I would set in power options to high perfomance.
CPU
Go to bios and look if there is any BCLK (Busclock, it should be 100.00Mhz~), you can do 102/103 if you are lucky, disable C-states and rest of that power saving.
Memory
I would suggest you trying first higher frequency (As i see max is 2400MHz.... set it to 2400 or enable the XMP if you see it, since it will save you a lot of time).
Other is making tigher timings, for example if your timing is 5-6-7-18 1T
5 is Cas, 6 tRCD (RAS to CAS), 7 tRP (RAS precharge), 19 is tRAS its sum of first 3 numbers 5+6+7=18 which can be -1 or +1
The tigher the better, but expect a bit voltage to add it.
up to 1.35V is safe...
Hello again,
CPU
Memory
Forgot to add "Memory stability test clickable link here"
GPU
Well since your PSU is kinda OLD I would not suggest to push voltage into GPU, just do basic overclock "CLICK HERE FOR VIDEO TUTORIAL".
But first fix your GPU in your other thread.
