How to Maximize CPU Usage? to get high performance. from Processor Power Management.
adhmomran
how to configure minimum and maximum in Processor Power Management to get high performance. i have desktop pc. i change minimum from 5% to 0% and maximum is 100% is this good or not for high performance
Set both to 100% if you want maximum clock speed. Also disable Intel speedstep or AMD cool n quiet in the bios, depending on which platform you're using. Keep an eye on temps to make sure you have sufficient cooling even though you're not actually overclocking. Modern systems are critically balanced on a configuration where core throttling and cooling are used in tandem to control thermal regulation and changing the configuration may exceed the units cooling capabilities during extended heavy loads.
