N nnchandru Reputable Jan 9, 2015 1 0 4,510 Jan 9, 2015 #1 I am running a KVM on Red had linux OS. When i am on my KVM with fullscreen... i want my taskbar of linux. IS this possible??
Solution skittle Jan 9, 2015 Full screen mode exists for its purpose: Full Screen You can't go about mixing one desktop with another inside a VM! At most you can run it in windowed mode and get this similar effect. Or simply shift to a different workspace.
A Alabalcho Titan Jan 13, 2011 14,016 433 81,090 Jan 9, 2015 #2 You can't have your cake, and eat it... Upvote 0 Downvote
skittle Splendid Dec 27, 2006 4,036 3 23,960 Jan 9, 2015 Solution #3 Full screen mode exists for its purpose: Full Screen You can't go about mixing one desktop with another inside a VM! At most you can run it in windowed mode and get this similar effect. Or simply shift to a different workspace. Upvote 1 Downvote Solution
ex_bubblehead Titan Moderator Aug 24, 2012 17,631 2,144 89,240 Jan 9, 2015 #4 Seamless mode will do what the OP asks. Upvote 0 Downvote
skittle Splendid Dec 27, 2006 4,036 3 23,960 Jan 9, 2015 #5 I know virtualbox and vmware support seamless mode. How do you enable seamless with KVM? Upvote 0 Downvote
ex_bubblehead Titan Moderator Aug 24, 2012 17,631 2,144 89,240 Jan 9, 2015 #6 From the usage pattern it appears that the OP is mistakenly using "KVM" when he actually means "VM". He should clarify the question. Upvote 0 Downvote
Ijack Splendid Jul 30, 2008 7,098 0 28,010 Jan 9, 2015 #7 skittle : I know virtualbox and vmware support seamless mode. How do you enable seamless with KVM? It can be done for Windows applications: https://nowhere.dk/articles/running-windows-applications-natively-with-seamlessrdp but I don't think it can for other guest OSs. But the alternatives that you suggest sound perfect (and less messing about). Upvote 0 Downvote
