How to remove write protection on my sandisk cruzer flash drive usb?
pjmelect
3,171
159
Unless you have worn the drive out through over use, then the problem is probably because you have a fake USB memory stick. All of the sticks that I have seen with this problem is due to the memory stick being fake and occurs when you exceed the true capacity of the memory stick.
Similar threads
