How to remove write protection on my sandisk cruzer flash drive usb?
SungJe
Hello,
I can delete, format or save new files in my 8GB Sandisk cruzer USB Flash drive... I've tried all recommended ways on the internet to remove the write protection but still those things doesn't fix the problem. my flash drive doesn't have physical switch
TenPc
2,472
59
You've asked this Question 9 times (in a row) and everybody has said the same thing, about some sort of on/off switch, on the side of the device.
Doesit show a drive letter in Explorerr?
Try a right-click then Properties of the drive then see if there is a check box for Read Only, untick that box, click OK button. Voila!
