How to set up TV as second monitor?
6
I have a DELL U2715H Monitor 2560x1440 resolution (currentlty set at 1920 x
1080) connected to my computer (Windows7) that has copies of all my former
movie DVDs on 2 internal hard drives.
Now I bought a Sony TV 32R412D with 1366 x 768 Resolution and I would like
to watch my movies on my TV.
Can I use an HDMI cable from the second HDMI port on my monitor to my TV
and set the TV as second monitor? Please let me know if this will be OK and
how I have to do it. I would only need the picture on my TV no need for
sound.
I am not very computer savy and have not much help here in a very small
town in North India. Neither the TV- nor the PC Guru knows what to do.
Yes, you should. Just leave your monitor connected via HDMI and then connect the HDTV using a DVI to HDMI cable (no audio) and you should be good to go.
-Wolf sends
MERGED QUESTION
Question from ornalink : "How to set up TV as second monitor?"
The computer guy comes tomorrow. I will give him your answer and hope he will know how to go about. If GT610 has no DVI output could we use a HDMI splitter and connect to the TV with HDMI cable?
Thanks so much for your prompt answers, Wolf.
that makes sense. Then the only option would be to install an additional video card or a new one with 2 HDMI outputs? If both options are possible which option would be better?
I just found out:
The GeForce 610 has Dual-link DVI
Able to drive industry's largest and highest resolution flat-panel displays up to 2560x1600.
So I should be able to connect.
-Wolf sends
Hello, this is old but I'm hoping someone will see this. Does anyone know if you can use a TV as a second monitor if you pirated Windows 10? Or if you can use a second monitor in general with pirated Windows.
Thank you.
