how to speed up a computer
banker
Respectable
May 21, 2016
309
hi I've noticed my computer has gotten slow over the years, and now even refusing to turn off when pushing shutdown (need help with that too) but is there a free way to speed up my computer, I also don't want to freshly install windows
You could strap a jet engine to it: https://hydrobuilder.com/s-line-8-728-cfm.html?utm_source=google&utm_medium=shopping&utm_campaign=736712&gclid=CI2Mi5205tECFcGLswodtu4Mqg
Or if you want you can go to http://www.bleepingcomputer.com and download and run the following programs in the order shown:
Rkill
JRT (Junkware removal tool)
TDSSKiller
Adwcleaner (Computer will need to restart)
Malwarebytes Antimalware
CCleaner
most of these are scan tools so you'll need to run the program and scan and remove whatever they find.
If it still running slow you should run chkdsk /r and windows disk defragmenter: https://www.tekrevue.com/tip/fix-hard-drives-chkdsk-windows-10/...
Rkill
TDSSKiller
CCleaner
https://support.microsoft.com/en-us/help/17126/windows-7-improve-performance-defragmenting-hard-disk
in the command prompt you wanna run chkdsk c: /r and it will ask you to schedule chkdsk the next time your computer restarts then restart your computer and let it run.
You can also check this out as it will let you know what programs your computer is running in the background: http://www.optimizingpc.com/windows7/windows_7_msconfig.html
I might reinstall after I upgrade my cpu, how do I even do that btw?
