Question How to start up a motherboard without power sw pins
Mlado53
25
I'm not sure if something is fried but the motherboard won't start when I jump start it with a screwdriver(its a really old one with a celeron cpu). Is there any other way to start it up?
TY
The pins is the only way to turn on the motherboard which inturn turns the psu on. Seems like there's a fault somewhere between the pins and the psu preventing a turn on signal getting through. Could be motherboard or psu.
Try turn on psu without the motherboard to test.
My old psu has a little exposed wiring on the to of the 12 pin connector on the motherboard that can be used to jump start it with a paper clip.
The psu has no fans but it works.
I have tried to jump start it and the jump starting worked from the top of the 12 pin connector but it didn't turn on.
I heard the que that it tried to turn on.
I will close this case as the motherboard is probably fried(RIP celeron).
