I will try to explain what I have, what I need, and how I plan to do it in full detail.
I'm trying to access my home router from a remote location.
I have the user and password of the router and physical access to the router.
I have an internet connection in my remote location where I can access the home router via internet.
The Router I am using is the Huawei B593 4G Router (Home Router).
I want to capture, save, and decrypt traffic/data from the home router at my remote location.
I will most probably be using Wireshark.
There will be only one device connected to the home router, this device will be an Iphone 4g.
On this device the apps that will be used are google chrome, whatsapp, Kik, Tango, BBM, and instagram.
Questions:
1) How do I access my home router from a remote location ? (in this case Laptop)
2) The iphone will be using the routers internet connection, So will Wireshark be able capture, save, and decrypt traffic/data that is being sent to and from this device ?
3) How do I use wireshark to capture, save, and decrypt the traffic/data that I need ?
Problems:
I have never used Wireshark before.
Thanks for the help.
Questions:
Problems:
