how to turn on wireless capability on MSI laptop
When you go to your WiFi to look for a connection, click on "Troubleshoot". It should find and solve the connection issue. It happens all the time on my Lenovo Laptop once I've been on Ethernet for a while and want to switch to WiFi
Im having same trouble with my Leveno MSI. Tried all fn and function key combos, nothing working. Problem solver did nothing just said no network connections available. Driving me crazy.
Okay, so your WiFi is enabled but not picking up any signals? Am I guessing your issue correctly?
I tried everything too and the answer ended up being simple. I tried F10 buttons and every other combination. My computer guy went into internet options, network and computer sharing, change adapters, then enable the wireless. Theres one connection for cable and one for wireless. Mine was on the cable adapter, although I dont know how it changed to that. But problem solved.
Go to internet options then network and computer sharing then change adaptors. There are 2 settins, one is for cable the other for wireless. Mine was on cable so I clicked on the wireless and enabled it. Problem fixed. Hope it works for you.
