How to use Chromebook as a monitor/TV screen for my Xbox 360.
Oct 3, 2018
So if the HDMI on the Chromebook is an output, and the HDMI on the Xbox is an output too, is there a cable that can come as HDMI and go in as like USB or something for the Chromebook? Then, how would I know it's working?
Laptop/Chromebooks/Tablets are not designed to be used as monitors. Yes it is possible using a capture card (which I doubt a Chrombook supports) but he latency would make it very hard to play on. If you want a monitor for your Xbox 360 then something like this https://www.amazon.com/HP-Pavilion-21-5-Inch-Monitor-22cwa/dp/B015WCV70W/ref=sr_1_3?s=electronics&ie=UTF8&qid=1538620013&sr=1-3&keywords=hp+monitor is about as cheap as you can go. Its actually a pretty good monitor form what I have seen, but be aware there is no sound on this monitor so you would have to have an external sound source https://support.xbox.com/en-US/xbox-360/console/connect-sound-system
