[SOLVED] How to use Multi monitor with I3 9100f
Mar 18, 2020
My Computer had I3 9100F procie and I am Using GTX 1650 Super ,but I cant use Multi monitor , it's only showing 1 monitor, the second monitor is not detected by windows, I am using Acer RG240Y monitor and Samsung TV.
i have tried many method but all of them not works
OK, so only the HDMI output is working? You tried HDMI to your ACER monitor and it works. You've tried HDMI to your Samsung TV and it works. However, when using the DP to HDMI cable to either device, it doesn't work.
Is this correct?
-Wolf sends
Yes it was connected with my Graphic Card, i am using DP to HDMI converter to my TV and HDMI cable to my Monitor, still Showing only 1 Monitor,
the Other one Not Detected
Is this correct?
-Wolf sends
Latest posts
