I have a media computer whose (relevant) guts consist of the following:
GIGABYTE GA-MA74GM-S2H http://www.newegg.com/Product/Product.aspx?Item=N82E16813128328
AMD Athlon 64 LE-1600 http://www.newegg.com/Product/Product.aspx?Item=N82E16819103199
2 GB DDR2 800
For OS and playback I use
Win XP Pro
VLC player
The computer is hooked to a 720p plasma TV. The onboard video is used. The most intense usage it gets is 720p movie playback (no gaming). My problem is that some movies at some times become choppy. It is only movies whose image covers the full screen and then only during a few intense moments. The task manager indicates that at those times the CPU is running 100%. I have experimented with overclocking the CPU and it does help, but I can't push it much past 2.5 gHz and even at 2.5 (where it's at now) it isn't smooth all the time. It really seems that it is just barely not quite enough... on most movies it is not a problem or is something I can put up with.
My question to you is this: what is the cheapest way to eliminate this problem? Here are the options I'm thinking of:
- Other software. The onboard video is ATI Radeon HD 2100. I have installed the newest version of ATI's Catalyst Control Center and use VLC's newest media player. Is there anything else I can do?
- A different OS. Someone suggested I install Ubuntu... any thoughts? Could this be just efficient enough to get the job done? Are there any issues with drivers for the mobo? I need to use the SPDIF output; will this be a problem? I've not messed with Linux before but figuring it out shouldn't be a problem. I might do this to experiment anyway.
- Video card. My thought is that installing a video card might drop the requirements on the CPU down just enough to keep it below max. Is this possible? Do you have any suggestions for a cheap, low profile, PCIE x16 video card?
- CPU. The socket AM2 CPUs are cheap. I could go with either the (45w) 4850e 2.5 gHz dual core for $54 or the (65w) 5600 2.9 gHz dual core for $67.
What do you think? Thanks in advance.
2 GB DDR2 800
Win XP Pro
VLC player
