(HTPC question) Is there a format with higher quality than blu ray?
Scotty99
434
I posted in this section as i am planning on building a HTPC.
Is blu ray the absolute top quality i can view on my HDTV? Or is there a way to either:
1. Rip blu rays (legally owned) to my HDD and get even higher quality with some kind of software.
2. Downloaded (legally)?
I know streaming is less quality than blu ray, so thats out of the picture for me.
I would prefer to have all my movies on my HDD anyways, so whats the best way to go about amassing a movie collection in 2012? (i assume buying blu rays and ripping them to HDD?).
HDTVs display at 720i, 720P, 1080i, and 1080p resolutions. 1080p is considered to be the current highest quality video; 1920x1080 pixels using a progressive vs interlaced scan. A bit dated article on differences between 1080i and 1080p: http://reviews.cnet.com/1080i-vs-1080p-hdtv/
Blu-Ray players send 1080p format video files to your HDTV so they are the highest quality video players available. There are differences in the quality of blu-ray players and HDTVs but I won't get into those differences.
1. Even if you could enhance the video via software, your TV would not be able to display resolutions higher than the native 1080p.
2. Download legally: Not likely...you may find some movies that can be downloaded legally but I haven't.
If you want the highest quality videos in your collection, then blu-ray or ripping blu-rays to hdd will give the highest quality videos. Tips/tricks for ripping: http://www.maximumpc.com/article/features/rip_your_movie_dvds_and_watch_them_anywhere
For now Blu-Ray is the highest video quality you can get. Therefore, the best solution to amass a HD movie collection is to buy the Blu-Ray and rip them to your hard drives. However, that can take a lot of storage space since movies are either on single sided Blu-Rays (25GB) or double sided Blu-Rays (50GB). Full rips can quickly eat away the space on 1TB or 2TB hard drives.
You can use software like HandBrake to encode your Blu-Rays to MKV files using the x.264 codec. But this is a time consuming process especially if you are trying to shoot for high video quality. Generally, speaking you can reduce a movie's storage size by about 50% and still retain very video quality. So that means a movie on a 25GB blu-ray disc will be about 12.5GB and a 50GB blu-ra disc will be about 25GB.
You cannot use video encoding software to increase video quality. That is impossible. The sole purpose of video encoding is to reduce the file size of the video. That is generally done by either tossing out some details that your brain will not notice or by compressing them.
If you have a 120Hz LCD HDTV (many people do), then you can use that to "help" increase picture quality. When a HDTV is operating in 120Hz mode it basically takes the video input of 60Hz or at most 60 frames, and doubles it. This is done by creating and inserting an interpolated frame between every two actual frame. This creates the illusion of more details, but some people do not like the affect it has on movies and they switch the HDTV down to 60Hz mode so that the HDTV does not do any sort of video processing.
Also 120Hz mode is to help with the playback smoothness of the video. Movies are basically recorded at 24 frames per second and TV programs are recorded at 30 frames per second. Both rates are actually slightly less, but I'll just use whole numbers. As stated, the video received by a HDTV is at 60 frames per second. Because TV programs are recorded at 30 frames per second; 30 divides evenly into 60 and 120 so when the HDTV is in 60Hz mode all the HDTV need to do is divide the input by 2 so that it can smoothly display the TV program. Likewise, in 120Hz mode the HDTV divides the output by 4 for smooth playback.
However, movies are different 24 does not divide evenly into 60, but it does divide evenly into 120 (divide by 5). Since 60 is not divided evenly by 24 this means that the HDTV repeats 6 frames every second which creates a little bit of video stuttering. Putting the HDTV in 120Hz mode eliminates the stuttering because the HDTV do not have to repeat frames due to the fact that 120 divided by 24 results in a whole number.
I can't add much to the above comprehensive answers. Basically, Bluray is the standard in HD right now...if you want to get the best quality from the disc through ripping, make sure you don't compress it in any way. I rip Blurays with DVDFab (which, despite the name, has a Bluray option), and store it on HDDs in the same file format as it is on disc. Some people store it as an ISO, then use a mounting option to play it back.
The best way to place movies onto HDDs, IMHO, is to use a home server. You can stick that in a cupboard, hook it up to a gigabit LAN and then have a low power HTPC by your TV which streams from the server. If you use a piece of software such as Total Media Theatre 5, which can read Bluray file formats, the server just hands files to the HTPC and can accordingly be relatively low spec (mine is powered by a 1.6GHz dual-core CPU). The HTPC itself can be built to be low-powered and quiet...check my sig for an example HTPC build.
The advantage of separate HTPC / server is that you don't need to deal with HDD noise in the lounge and also don't have to limit the number of HDDs to a HTPC chassis. Also, if you have an A/V receiver, you can take advantage of bitstreaming audio off of Bluray to get up to 7.1 surround sound.
Which is nice. :)
