Huawei MatePad 13.2-inch tablet uses unknown HiSilicon Kirin 9000W processor.
Huawei's MatePad Pro hides an unknown Kirin 9000W : Read more
75 amps to burn your house down. Chinese marketing nomenclature has a lot to be desired. P/E. 9000w/120v..Huawei MatePad 13.2-inch tablet uses unknown HiSilicon Kirin 9000W processor.
A 105w processor at 1.4 v would draw 75 amps, not uncommon to draw much more than that in a desktop CPU.One of the new features of the chip is arc welding!
75 amps is in the range for some types of welding!
You will never draw a full 105w under normal circumstances. PC would not last long under full bore conditions. My 5950x never gets close to it's burn a hole in the motherboard "I" draw. Better have a 2000w power supply....A 105w processor at 1.4 v would draw 75 amps, not uncommon to draw much more than that in a desktop CPU.
What do you consider "normal circumstances"? Even if we limit ourselves to consumer parts, you can easily get modern, high end (or even mid range) CPUs to draw 105+ W doing things like rendering, encoding, etc., and they can run like that indefinitely. So long as you have a good motherboard and cooling, you aren't going to burn anything out.You will never draw a full 105w under normal circumstances. PC would not last long under full bore conditions. My 5950x never gets close to it's burn a hole in the motherboard "I" draw. Better have a 2000w power supply....
13900K draws 295w in Blender at stock settings no OC. Also not sure why you would need a 2000W PSU to power 105w.You will never draw a full 105w under normal circumstances. PC would not last long under full bore conditions. My 5950x never gets close to it's burn a hole in the motherboard "I" draw. Better have a 2000w power supply....
I was being sarcastic. You will never draw full current unless you are doing weird things to the BIOS. Storage drives and peripherals are nominal. I bought a 1200w PSU a few years back. People thought I was crazy. Better be a quality supply with room to move. 1200w doesn't sound so crazy today does it? A quality supply could last 10 years. That is where some people miss the boat. First and foremost you start with good power distribution, the heart of a PC. Then build your killer machine.13900K draws 295w in Blender at stock settings no OC. Also not sure why you would need a 2000W PSU to power 105w.
https://gamersnexus.net/cpus/intels-300w-core-i9-14900k-cpu-review-benchmarks-gaming-power
I have had a 12900k which would happily eat 300w continously. The z690 aorus master that I used had 22 x 105A power stages. Not that that CPU can handle 2200 amps, but the motherboard power delivery is designed to that spec. 75amps is nothing at all.You will never draw a full 105w under normal circumstances. PC would not last long under full bore conditions. My 5950x never gets close to it's burn a hole in the motherboard "I" draw. Better have a 2000w power supply....
I'd challenge you to find a modern enthusiast grade motherboard that can't supply at least 1000 amps to the cpu socket.One of the new features of the chip is arc welding!
https://logi.wiki/index.php/Resistance_to_Ground_ListI'd challenge you to find a modern enthusiast grade motherboard that can't supply at least 1000 amps to the cpu socket.
15 ohms would be the resistance when powered off (assuming the numbers in the source you provided are correct). The load it presents will be completely different when operating. If that resistance was applicable while running, it would only draw 63mW ([0.975^2]/15), which is obviously not correct.https://logi.wiki/index.php/Resistance_to_Ground_List
http://valid.x86.fr/rlt0m0
If we use the i7-4770HQ as an example it has a vcore of 0.975 volts and a resistance of 15 ohms.
0.975 volts / 15 ohms = 0.065 amps
i7-4770HQ is a bit dated but it was one of the only processors I could find with resistance values.
Having said that I have a hard time believing modern motherboards are over-engineered to supply 15,384 times (1000amps/0.065amps) the amps of a cpu only 10 years old.
Jiga watts of power!Presses power button on phone. 📳 (hears noise from Back To The Future speaker scene as he turns it on.)
..or you could just look at the spec sheet of a few motherboards to see what I'm talking about. I think you'll commonly find a dozen or two power phases fed 70+ amps each.https://logi.wiki/index.php/Resistance_to_Ground_List
Having said that I have a hard time believing modern motherboards are over-engineered to supply 15,384 times (1000amps/0.065amps) the amps for cpu only 10 years old.
