Question Huion Q11k v2 no pressure and stuck cursor
Apr 12, 2019
Hey
Ive absolutely ran out of ideas, disabled Windows INK, used the fixmypen thing, rebooted the pc, pluged the tablet in/out, reinstalled the drivers, updated the drivers, tried various softwares and nothing. The problem is with how the pen works - once you press to draw the cursor will freeze itself and when you'll move it it wont draw anything untill it has moved a certain distance with proper pressure to just draw a perfect line from the point where it got stuck to where it would unstuck, after that it works like it should. But the problem is with the lag, its just impossible to work with it. Ive got no idea how to fix it so im reaching out here, hoping someone may help out.
UPDATE:
Tablet works on the other PC, flawlessly. I have uninstalled the driver but the tablet still acts like its installed, however the issue stays. I'll add that I have recently reinstalled my OS and cleaned all the drives, it worked fine before and now its bleh
