Hyper 212 EVO Size Help
hassanabbas9146
Commendable
Mar 9, 2018
29
I have i7-3770K with a Asus Z77-A motherboard and 4x4 PNY RAM. Im not sure if it would fit because i feel like the ram slots and the blue thing on the side is way too close for the Hyper 212 EVO to fit. Thank you for any help.
I presume the "blue thing" you are referring to is the VRM heat sink. Not a problem. The fan would not normally go on that side, and the cooler itself won't reach out that far. As to the RAM, unless you have monster-tall RAM, the 212 EVO's fan mounting grooves allow for quite a bit of height adjustment on the fan.
This is my ram but 4x4: https://www.amazon.com/PNY-1333MHz-PC3-10666-Desktop-MD8192KD3-1333/dp/B004DHNAGM, and thank you for your response, I will be buying it soon.
You won't have to raise the fan a bit for that height RAM. Not probs.
