[SOLVED] Hyper 212 LED turbo Dimension
riobijoy
62
Hi,
I am going to buy cpu cooler of cooler master hyper 212 led turbo and i have cooler master cm force 500 cabinet so can hyper 212 fit in that cabinet
Cooler dimension .
DIMENSIONS (L X W X H)120 x 108 x 163 mm / 4.7 x 4.3 x 6.4 inch
HEAT SINK DIMENSIONS (L X W X H)120 x 60 x 160 mm / 4.7 x 2.4 x 6.3 inch
Cabinet.
MAXIMUM COMPATIBILITY - CPU COOLER HEIGHT163.9mm / 6.5 inch
Yes, it will fit. The Hyper 212 EVO Turbo LED is 163mm tall WITH the fan installed. Your cabinet supports coolers that are 163.9mm tall, so it will fit, just barely. Honestly it might be better to look at a shorter cooler, as less than 1mm clearance is not always enough to account for variables.
The Gammaxx 400 is a better cooler than the Hyper 212 EVO, and is only 154.5mm tall.
Reactions: riobijoy
Thank you so much for helpfull reply
Is gammaxx 400 support LGA 1155 and LGA 1151
