Hyper-link Problem in Internet Explorer
Thoth
86
Archived from groups: microsoft.public.windowsxp.general (More info?)
Whenever I'm using IE Version 6.0.2800 - clicking on ANY hyper-link takes me
to my home page rather than the page the hyper-link points to. The problem
just started sometime in the last week - don't know what I did to change my
settings, but it's obviously VERY annoying to be reading, say an article on
Cnet, click on a hyper-link expecting to go to a new article, and end on on
my home page instead. If it makes any difference - my home page is
Google.com. Anyone have any ideas on how to change this?
Thanks, Philip
"Thoth" <Thoth@discussions.microsoft.com> wrote in message
news:6305EACE-81B0-47AF-8765-813EEDB319EF@microsoft.com
> takes me to my home page rather than the page the hyper-link points
> to. The problem just started sometime in the last week - don't know
> what I did to change my settings, but it's obviously VERY annoying to
> be reading, say an article on Cnet, click on a hyper-link expecting
> to go to a new article, and end on on my home page instead. If it
> makes any difference - my home page is Google.com. Anyone have any
> Thanks, Philip
From http://www.fjsmjs.com/OE/nolinks.htm
Open Windows Explorer.
Go to Tools | Folder Options | File Types.
Scroll down to URL:HyperText Transfer Protocol and select it.
Click Edit or Advanced, depending on your Windows version.
Select 'open'.
Click Edit.
"Application used to perform this action" should read:
"C:\PROGRAM FILES\INTERNET EXPLORER\iexplore.exe" -nohome
(Check the path to iexplore.exe to make sure that is correct and use the
double quotes.)
DDE should be checked and in the boxes below it you should have:
#1:
"%1",,-1,0,,,,
#2
IExplore
#3 (blank)
#4
WWW_OpenURL
URL:HyperText Transfer Protocol with Privacy should be the same.
Sometimes it is necessary to uncheck Use DDE.
If that doesn't fix it, go to Start | Run and type
regsvr32 urlmon.dll
Frank Saunders, MS-MVP OE
Please respond in Newsgroup only. Do not send email
Protect your PC
http://www.microsoft.com./athome/security/protect/default.aspx
http://defendingyourmachine.blogspot.com/
Hi Frank - That "fixed" the problem. Thank you for your quick response, AND
very clear directions.
Regards, Philip (Thoth)
> > Thanks, Philip
> Select 'open'.
> Click Edit.
> double quotes.)
> #1:
> "%1",,-1,0,,,,
> #2
> IExplore
> #3 (blank)
> #4
> WWW_OpenURL
> regsvr32 urlmon.dll
> Protect your PC
news:3525C7EA-450A-4B0B-B70F-15D96E88AD7F@microsoft.com
> response, AND very clear directions.
Thanks for the feedback.
Protect your PC
