Question HyperX Pulsfire Dart Wireless Mouse - NGENUITY won't recognize anymore my mouse
May 21, 2023
Hello there,
I'm using HyperX Pulsfire Dart Wireless Mouse for some time now and all worked properly until today. NGENUITY won't recognize HyperX Pulsfire Dart Wireless Mouse no more. I hope you can help me about this problem.
Thank you in advance.
Kind regards.
Does the mouse behave the same way when you hook it up to another system? If it doesn't then, the mouse would be in need of a replacement/RMA. If it does work without an issue on the donor system, then there might be an issue with your platform, namely you should look into reinstalling your chipset drivers.
If the app is the one that doesn't see the mouse, uninstall the app and reinstall it after a reboot, reinstalling the app in an elevated command, i.e, Right click installer>Run as Administrator.
