[SOLVED] HyperX Quadcast vs. Audio Technica AT2020
It really depends on what you're going to be doing.
ATX2020+
it has a better sound quality and a wide Polar Pattern which makes it a better option for Music recording or anything else that needs a finer detail.
Hyper X
The sound quality isn't as detailed or as nice in general but it's $30 cheaper and gives you some perks.
-Internal pop filter
-Multi-device and chat program compatibility
-Tap-to-Mute sensor with LED indicator
This seems much more targeted to gamers and Twitch streamers and the quality is good enough for these uses. Does that make more sense?
ATX2020+
Hyper X
ATX2020+
Hyper X
Yep! Thanks!
