Question I am looking for a "Weather-Proof" USB-C male to USB male charger cable for my outdoor home security camera. Rainproof, snowproof and waterproof ?
SeriousGaming101
330
I have a couple home security cameras which are solar powered but also can be charged with a usbc cable: https://us.eufy.com/products/t88711w1
The problem is that these cameras are using more power than they are gaining from the built-in solar panels so the battery power gets low.
So my plan is to get a couple of short USB-C male to USB male cables such as these: https://www.amazon.com/CableCreation-Braided-Compatible-MacBook-Resistance/dp/B01CZVEUIE
I plan on leaving these cables outside plugged into the camera. And when the camera power gets too low, I can instantly charge the camera with a longer cable without unplugging the whole camera down from the wall. So, I am looking for these USB-C male to USB male cables: https://www.amazon.com/CableCreation-Braided-Compatible-MacBook-Resistance/dp/B01CZVEUIE BUT the only thing is that they HAVE to be weather proof.
The short USB-C male to USB male cable MUST BE Rainproof + Snowproof + Water proof and must make sure that water can't get into the camera's back USB-C slot while the cable is plugged in all-year-round. I can seal the USB side with a USB cap but the USB-C side must be water-tight.
Can someone recommend me a short USB-C male to USB male cable that is completely WEATHERPROOF while plugged in outdoors?
Did you google "outdoor usb connectors" ??? There are lots. L-Com is known for weatherproof equipment -- https://www.l-com.com/usb-waterproof-usb-cable-assemblies
But if the USB on the camera is not designed for a weatherproof connection, then that will be the weakest link.
Regarding:
"The problem is that these cameras are using more power than they are gaining from the built-in solar panels so the battery power gets low."
Make and model cameras? Power/battery specs? Any power saving options on the cameras?
The camera's specs may have been established under ideal circumstances. Camera configured for minimum power usage and installed in a very sunny environment.
Are the camera's solar panels positioned to take advantage of peak sunlight hours/directions?
Where the camera is aimed may not be optimal positioning for its' built-in solar panel.
Solar panels - clean and clear?
Also:
"And when the camera power gets too low, I can instantly charge the camera with a longer cable without unplugging the whole camera down from the wall."
What will be the power source for the longer cables?
Just some thoughts that came to mind.
Regarding:
Also:
I have an outdoor 3-prong outlet that I can use a 10-feet cable to charge the camera as a second option. It's a Eufy 3 S330 camera. It's optimally positioned for solar but there isnt much sunlight in the Winter compared to the Summer.
