Hi,
Depending on the version you have, it might not be included.
If it is included, do you save the file to hard drive or do you just open in browser.
If you open powerpoint in browser it might not work for some reason.
Also if you try to open a office 2010 it might not be compatible and therefore you need to download office 2003/2007/2010 compatibility pack.
good luck
