Hello everyone, I am not sure if this the correct place to post this but I need some help.
I am trying to fix my old TV, I don't remember the model but it has this panel (LC370EUH-SCA1-LG - https://datasheetspdf.com/datasheet/LC370EUH-SCA1.html). Actually the TV had issues like visual noise and slow motion, so after doing some research I came to the conclusion that the main board had issues processing the images. That's why I bought a Universal TV board and tried fixing it.
Those are the parts that I got:
1) https://www.aliexpress.com/item/32826581382.html?spm=a2g0s.9042311.0.0.4fe24c4dHp8CwD
2) https://www.aliexpress.com/item/32828282415.html?spm=a2g0s.9042311.0.0.4fe24c4dHp8CwD
The parts arrived and it took me twice as much research as I had done before, to figure out how I could connect the universal board to my TV's power supply. And I made it I had backlight.
The problem is that I had no picture at all, I tried to install different firmwares, and tried to use some other cables I had, but nothing changed.
I suppose the connect board that I also bought isn't compatible with my panel.
That's why I wanted to ask someone before I ditched the project. I would appreciate any help, suggestions, or even any compatible parts that you know they would work!
Thanks for your time and help, in advance!
