I bought a prebuilt pc from ibuypower are these parts compatible? and will everything work
Dankdab
329
Limited Time Offer 1 x [FREE] - iBUYPOWER High Performance Gaming Mouse Pad ($19 Value)
Limited Time Offer 1 x [FREE] - GAMDIAS Hephaestus II Gaming Headset ($49 Value)
Limited Time Offer 1 x [FREE] - iBUYPOWER MEK Mechanical Gaming Keyboard ($79 Value)
Case 1 x iBUYPOWER Slate Gaming Case (2x Side Glass Panel)
Case Lighting 1 x iBUYPOWER RGB Smart Lighting (Software Controlled LED Lighting Kit) - [FREE] 1 Smart Lighting Strip - Top of the case
Processor 1 x Intel® Core™ i7-7700K Processor (4x 4.20GHz/8MB L3 Cache) - Intel® Core™ i7-7700K
Processor Cooling 1 x Corsair Hydro Series H55 120mm Liquid CPU Cooler - Standard 120mm Fan
Memory 1 x 16 GB [8 GB X2] DDR4-2400 Memory Module - Corsair or Major Brand **Free Upgrade to DDR4-3200 ADATA XPG**
Video Card 1 x NVIDIA GeForce GTX 1080 - 8GB - ASUS STRIX RGB (VR-Ready) - Single Card
Free Game Bundle 1 x [FREE Game Download] - Intel Holiday Gaming Bundle: Warhammer: End Times and Tom Clancy's Rainbow 6 Seige - w/ purchase of Intel Core i7 Processor Systems
Motherboard 1 x MSI Z270 PC Mate -- 3x PCIe 3.0 x16, 6x USB 3.1 Gen1, 1x USB 3.1 Gen2 Type-C [Intel Optane Ready]
Power Supply 1 x 850 Watt - Corsair CX850M - 80 PLUS Bronze, Full Modular
Advance Cabling Options 1 x Standard Default Cables
Primary Hard Drive 1 x 500 GB Samsung 850 EVO SSD -- Read: 540MB/s, Write: 520MB/s- - Single Drive
Sound Card 1 x 3D Premium Surround Sound Onboard
Network Card 1 x Onboard LAN Network (Gb or 10/100)
Operating System 1 x Windows 10 Home + Office 365 Trial [Free 30-Day !!!] - (64-bit)
Mouse 1 x iBUYPOWER Standard Gaming Mouse
Advanced Build Options - Packaging 1 x iBUYPOWER Specialized Advanced Packaging System - Protect your investment during transportation!
Warranty 1 x 3 Year Standard Warranty Service
Rush Service 1 x Standard Service - ships in 2 to 3 weeks
Those pre-built sites won't let you pick parts that are incompatible, and you won't have to set up the liquid cooling but you do have to take out the internal packaging when you get it
That packaging option uses expanding foam to protect the inside of the case so make sure you take the side panel off and take the foam bag out and also check for anything that may have come lose during shipping (at most it will still be where it is supposed to be, just not securely plugged in depending on how rough the shipping was), takes 2 minutes and is very easy to do given that the shipping wasn't too hard on it
Once you do that all you do is turn it on and go through the windows 10 setup
Should be up and running in about 10 minutes after you...
Should be up and running in about 10 minutes after you unpack everything from the box
