[SOLVED] I bought new parts and the PC is not POSTing ?
what type of hdmi or display port are you using take a picture of the rear of the case.
also flip the radiator so that the tubes are at the bottom of the case going up towards the cpu otherwise it will kill the pump faster and the actual block will be filled with mostly air in that configuration.
View: https://youtu.be/BbGomv195sk?feature=shared
Where do you expect me to fit does tubes ? I’m not cutting my BRAND NEW CASE FOR THAT.
Also I already send back the motherboard. I used the same hdmi in my previous build i know it works .
View: https://imgur.com/a/6LnsOMg
Ah, great that you knew about that already! Some don't.
That was the first thing i tried when installing it
Tho honestly i should have bought the h100 got the 150 really cheap like 70€ cheap from amazon warehouse it just had some bend fins nothing missing and it’s seems to work .
