[SOLVED] I can't open bios after reset CMOS battery
sumon5555
Hello,
I have a desktop computerc with windows 10 OS. Here is configuration mobo: Foxconn h81
Prossessor: Intel core i5 4460 and 4 GB ram.
Two days ago when I power on the pc it didn't run windows. Just open a black window there was "reboot and select proper boot device". Then I reset the jumper and CMOS battery. After few minutes turn on the pc it says "f1 to continue, del to setup" . I press del many times but can't go to BIOS. I'm still trying but can't.
Hello,
Try to reset the CMOS again , and check ur boot order , maybe u'll find the fix to the problem there , the first hdd/ssd that appears at the top of the list should be the one that u have windows on , if its not just put the one that u have windows...
Make and model of your PSU and it's age? Might want to see if the Num Lock LED is responsive when you press the Num Lock key on the keyboard. If it's unresponsive, it's possible that your system has hanged due to a possible issue with either the PSU or the storage/boot drive.
On second thoughts, please list your full system's specs like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS: Version of the OS.
Hello,
Try to reset the CMOS again , and check ur boot order , maybe u'll find the fix to the problem there , the first hdd/ssd that appears at the top of the list should be the one that u have windows on , if its not just put the one that u have windows on above so it boots from it.
Reactions: sumon5555
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
and yeah please list ur specs
