I dont understand what "ome Intel H81 chipset motherboards may need a BIOS update prior to using Haswell Refresh CPUs." HELP
the bios of any motherboard has hardware code for cpu and memory. if the code is missing and you put in a new cpu in a mb. it may not post or it may not boot right to where you can fix it. with some mb the bios chip can be removed some are soilder onto the mb. if the mb your looking at has a fixed bios chip you have to send the mb to the vendor to be reprogramed.
but it will work?
but it will work?
