Jun 4, 2020
15
I need help on how i can use its a 2.9 but is 3.2 turbo. I downloaded amd overdrive and tried to turn on turbo but it only maxes out to 2.9 how do I make it use the 3.2 turbo?
bryanc723
218
19
10,615
18
Run a CPU demanding task. You're trying to overclock instead of use the turbo is what it sound like. The CPU should automatically ramp up to the 3.2 in short bursts, but not stay there.
Depending on which CPU this is, that 3.2GHz Turbo speed might only apply in single core workloads and if your CPU loads anything more than a single core you drop down to a lower speed. In that case if you want 3.2GHz on all cores, you'd have to overclock.
