• Now's your chance win big! Join our community and get entered to win a RTX 2060 GPU, plus more! Join here.
    Meet Stan Dmitriev of SurrogateTV on the Pi Cast TODAY! The show is live August 11th at 2:30 pm ET (7:30 PM BST). Watch live right here!
    Professional PC modder Mike Petereyns joins Scharon on the Tom's Hardware Show live on Thursday, August 13th at 3:00 pm ET (8:00 PM BST). Click here!
Question I have three chassis fans that wont turn on
Jul 5, 2020
6
I have a amd ryzen 9x configurator, went to EZ mode thought i had activated the chassis fans and none of the fans came on. I just got this yesterday and do not want it to melt already. Do i not have something plugged in or is it defective
Jul 5, 2020
6
All the fans are plugged in, I checked all the connections.
I went into Bios, checked the fans, and my Chassis fans were checked to be off, so I unchecked them, restarted still nothing. (I changed the settings so that all fans should be on, only my cpu fan, AIO Pump, and Exhaust fan are on.
Jul 5, 2020
6
Are the fan headers set to auto or DC (voltage) or pwm mode. Check the minimum speeds in the fan curve settings, many cheap case fans require 7v to start, many bios will assume 5v for low temps.
The fans were set to DC, changed to PWM and even set to full speed just to test, still nothing.
Karadjgne
Ambassador
Is there a fan switch?it's usually somewhere near the front bezel. Many of those cases have a manual switch to control the speeds because the case fans are 3pin, not pwm 4pin, so get powered by sata/molex to a hub not the motherboard.
Jul 5, 2020
6
Where would this be located in the case (not familiar with PC)
Karadjgne
Ambassador
Mine is right above the optical bay, behind the door. Sometimes it's the pc reset button or another switch right next to it. You may need to physically trace a fan wire and see exactly where it goes.
If you can't figure it out, I'd call CyberpowerPC, they built it, was supposed to be tested and shipped in working order, and are intimately familiar with that case and how it's wired up.
Jul 5, 2020
6
Yeah Im gonna end up calling, the pc works great when playing I just don't want it to burn up.
Thanks for the help.
