I just built my first pc and everything is on,but my gpu came with a 6 pin connecter with 2 white connecters attached to it. W
The Corsair CX600 comes with two (6+2)-pin PCI Express supplementary power connectors. You don't need to use any of those "6 pin connecter with 2 white connecters attached to it" adapter cables.
That PSU should just be sufficient to power the MSI Radeon R9 290X.
What's the brand and model of the PSU? If the PSU has an output cable with a 6-pin or (6+2)-pin PCI-E power connector on it then use that. If your PSU doesn't have any output cable(s) that have a 6-pin or (6+2)-pin PCI-E connector on it then that usually means the PSU's +12V rail is too weak to power a discrete graphics card that requires any PCI-E supplementary power connectors.
I's the msi r9 290x and my psu is the cx 600.
Yea it worked thank you i was getting worried for a second.
