[SOLVED] I Need a build Advice
Mar 26, 2020
I want to upgrade my pc, my current rig is:
Motherboard: P8Z77-V LX
CPU: Intel Core i7-3770K
GPU: Radeon STRIX RX 580 O8G
RAM: Kingston HyperX 4x4GB (KHX1600C9D3/4G)
to...
Motherboard: MSI Z390-A Pro
CPU: Intel Core i9-9900K or i7-9700K
RAM: Patriot Viper 4 Blackout 4x8GB
Is there a GPU bottleneck if i have a to powerful CPU? Any help is appreciated
I'd recommend getting a beefier GPU if your budget allows it. Both of those CPU's will handle a 580 extremely easily, and your graphics will only be limited by the capabilities of the GPU itself.
