I need a CPU MoBo and CPU Cooler
iArranx
169
Hello people, im after a new CPU preferably an i7 and a new mobo and a new CPU cooler
My budget is £400 - £500
I also need a mob that will use my current memory my memory is
8.00GB Dual-Channel DDR3 @ 824MHz (11-11-11-28)
It's komputerbay with the blue metal on it
All suggestions will be considered as im going to buy these in 4 days time.
Many many thanks people.
Price is in £ as im from uk and sr-71 blackbird i mean like i already have 8gb of the komputerbay memory could i buy another 8gb of the exact same memory and put it in my new setup so i'll have 18gb?
Try this
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor (£257.94 @ Aria PC)
CPU Cooler: be quiet! Dark Rock 3 113.8 CFM Fluid Dynamic Bearing CPU Cooler (£45.59 @ Aria PC)
Motherboard: ASRock Fatal1ty Z97X Killer ATX LGA1150 Motherboard (£106.76 @ Scan.co.uk)
Total: £410.29
Generated by PCPartPicker 2014-10-05 03:49 BST+0100
or this
Motherboard: Asus MAXIMUS VII HERO ATX LGA1150 Motherboard (£155.00 @ More Computers)
Total: £458.53
They're both good mobo's but people seem to prefer the asus. Also you can select a water cooler like the h100i if you want. I chose air because it is more quiet and I prefer them.
Hello gamer thanks for the reply, im looking for a water cooled cooler if possible also could you answer my question i had above about the memory, i currently have 8.00GB Dual-Channel DDR3 @ 824MHz (11-11-11-28) could i buy another 8gb of the exact same memory and would this memory fit into this mobo, as these are the parts im gonna buy let me know what you think of them.
Thanks
Mobo - http://www.amazon.co.uk/dp/B00K8K992W/?tag=pcp0f-21
CPU - http://www.amazon.co.uk/Intel-4790K-Processor-4-00GHz-Socket/dp/B00L8JZOSU/ref=sr_1_7?s=computers&ie=UTF8&qid=1412454305&sr=1-7&keywords=i7+cpu
CPU Cooler - http://www.amazon.co.uk/Cooler-Master-Seidon-120V-RL-S12V-24PK-R1/dp/B00FFCB0BG/ref=sr_1_5?s=computers&ie=UTF8&qid=1412454380&sr=1-5&keywords=cpu+cooler
Since you're ram is running in dual channel that should be 1600mhz so I would assume it would work, although I am not ram expert. Im not familiar with the brand, but if its desktop ram it should work fine. But to make sure try those out before you buy another set.
For the Mobo, I have heard MSI has poor QC so I would stay away from them. The Asrock and the Asus I mentioned above are great boards. This is also a good one.
Motherboard: Asus Z97-A ATX LGA1150 Motherboard (£106.19 @ Aria PC)
Total: £106.19
Generated by PCPartPicker 2014-10-05 05:00 BST+0100
The cpu cooler is not a particularly good one so dont expect very good cooling. If you spend under $50 I would recommend an air cooler as they are much better at that price. These are the cheapest water coolers I would recommend, although a good air cooler at that price will perform better and be quieter.
CPU Cooler: Corsair H90 94.0 CFM Liquid CPU Cooler (£63.99 @ Amazon UK)
CPU Cooler: NZXT Kraken X31 69.5 CFM Liquid CPU Cooler (£56.39 @ Aria PC)
Total: £120.38
Generated by PCPartPicker 2014-10-05 05:02 BST+0100
I want a i7 for gaming streaming photoshop etc.
