I Need a Displayport to HDMI Cable @ 75hz
malakargaim
9
Okay, so I just ordered two new monitors that are 1080p with 75hz. My graphics card is a GTX 1060 6gb and it has one full-size DVI port, one DisplayPort, and one HDMI. The HDMI is currently running to a tv leaving me with the DisplayPort and DVI left. Both monitors have HDMI. I have this cable, but I read that it doesn't support 70hz. So, in short, I need a DVI to HDMI cable that supports 75hz and a DisplayPort to HDMI cable that supports 75hz both at 1080p. If I can still use that cable it would be great.
I have tested this DVI to HDMI cable up to 1080p 144 Hz:
https://www.amazon.com/dp/B004S4R5CK/ref=cm_sw_r_cp_apa_NXZuAbMTCJH1P
(Note to anyone finding this from Google results or something, you can only get 120+ Hz with this from a DVI computer to an HDMI display, and only if the display supports 120+ Hz over HDMI. This will NOT work for connecting to a DVI monitor at 120+ Hz)
I have also tested this DP to HDMI adapter up to 1080p 120 Hz:
https://www.amazon.com/dp/B01GW8DZV4/ref=cm_sw_r_cp_apa_9ZZuAbPAAZY0Z
Pair it with any HDMI cable you want.
Reactions: xTatersaladx
