Hi guys.
So I've had some troubles over the past few days. I bought an Insignia 520W ATX Power Supply - http://www.bestbuy.com/site/insignia-520w-atx-power-supply-silver/5610116.p?id=1219144863171&skuId=5610116
No power. Everything connected but nothing works. I took it around to make sure that everything was plugged in, and sure enough, it was. I returned the power supply.
Then I bought this one:
Thermaltake - SMART Series 650W Bronze Power Supply - http://www.bestbuy.com/site/thermaltake-smart-series-650w-bronze-power-supply-black/8733872.p?id=1219365660388&skuId=8733872
And that made my PC start smoking. I've done all the necessary plugins (even the local PC shops made sure of that, again). How do I know what power supply works? Is there one I can buy right off the bat that you guys know of that would work?
The guy at Geek Squad (one of the places that checked this out, ugh) said that it didn't have the right connections for the power supplies they had. How do I know what's right for my mobo? I'll probably try the local Micro Center for the next run of power supplies so I'll have more options.
Edit: To help this discussion, I want to note that I've followed that list of instructions floating around here prior to this post.
Update: I think I found the problem. According to a guy who bought the Thermal on Amazon, it's missing a 4pin thingy.
"Con: there is NO 4pin ATX cable like most other PSU's. I had to buy a molex to 4pin ATX converter cable. For a PSU to this quality, they should had a 4pin ATX."
I don't understand what that means, but I guess I need an adapter for this particular PSU?
