i have 220$ what i should upgrade in this pc
Core i3 6100
psu 180 W
MB 0X30F617A
RAM 12 2133 mhz
ssd 128
hdd 300
Core i3 6100
psu 180 W
MB 0X30F617A
RAM 12 2133 mhz
ssd 128
hdd 300
what do you plan on mostly using a system for?what i should upgrade
That money would be better spent getting a refurbished PC like this. https://www.newegg.com/dell-optiple...stations/p/1VK-0001-6G532?item=9SIA5WMKA21127
mostly gamingwhat do you plan on mostly using a system for?
thank you.That money would be better spent getting a refurbished PC like this. https://www.newegg.com/dell-optiplex-7070-business-desktops-workstations/p/1VK-0001-6G532?item=9SI
thank you.Where this is a good suggestion, be aware that the seller rating isn't where it should be. Check to see if you can find it either direct from Newegg, or a seller that (IMO) is no less than 4.9/5.
mostly gaming
if you are intending any sort of AAA games from the last few years then i would really suggest putting this money away for some time and continue saving.have 220$...mostly gaming
