APPROXIMATE PURCHASE DATE: This week
BUDGET RANGE: around $1000
SYSTEM USAGE: Gaming, Music Production, Photoshop,
PARTS NOT REQUIRED: Speakers, mice, keyboard
PREFERRED WEBSITE(S) FOR PARTS: newegg.com
PARTS PREFERENCES: AMD CPU
OVERCLOCKING: In the future
SLI OR CROSSFIRE: In the future
MONITOR RESOLUTION: 1600 x 900 for a 20 inch might go smaller to a 19 inch
ADDITIONAL COMMENTS: I need a second opinion on the system build.
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=18108308
Things I need help with.
RAM: There are two on the list not sure which one I should get?
CPU: Are they both the same?
Graphics Card: I need one that has the most bang for the buck. I might drop the one on the list if its over 1000.
Power Supply: Do you think I should go with the 700W? I plan to overclock and upgrade in the future or is it to much?
If you can help me out I appreciate it.
