I need help after replacing the chip, please!
ffleader1
63
Ok
I used to have a core 2 duo e4300 (stupid) before installing a dual-core e5700 (which is about an hour ago).
But when I use CpuZ to check my performance:
http://imageshack.us/photo/my-images/196/wtfsyw.png/
Evey thing looks exactly like the e4300, except the chip name. 😱
So what must i do to get the real e5700
Please instruct me well. Thanks (my mobo is D946GZIS)
I was going to recommend a BIOS update, but as you've said it's the latest, throw that recommendation out the window :lol:
However on a side note, it might be an issue with Windows. Reinstalling may fix this issue, however, I would prefer you try the thermal compound I suggested first :) you'll need it regardless, anyway! And it's always handy to have some around the house, especially if you're a somewhat-techy guy that loves...
I tried the program and when my system idle process becomes 0, i can still click to folders like normal :??: My cores temperature is about 55~60 C (when using prime 95) and i didnt use thermal compound
What do you mean 'i can still click folders like normal' ? Is your PC acting strangely when it's at 100% load?
However, you will want to pick up some thermal compound and apply that to your CPU. I'm thinking it's throttling (lowering frequency; degrading its' own performance to prevent overheating) to prevent itself from burning out.
My computer doesn't act strangely when it's at 100%. In fact, it acts normally.
Beside, that thermal compound is actually that important 😱 ?
All i thought is a good fan, because i don't overclock my CPU.
Yes, thermal compound is VERY important. It doesn't matter if you overclock your CPU or not, it's essential.
Thermal compound is a material that fills in the microscopic gaps between your CPU and heatsink. Those tiny gaps contain air, which trap heat, which leads to your CPU not being able to dissipate as much heat as it potentially could.
Sounds important
Maybe i will buy it tomorrow and check the result.
This is the first time i replace a chip and it took me 2 hours
Can't imagine getting everything out again.
But i still wonder, why my CPU runs at the extract speed of e4300?
will update bios help? (although my bios version is the latest)
However on a side note, it might be an issue with Windows. Reinstalling may fix this issue, however, I would prefer you try the thermal compound I suggested first :) you'll need it regardless, anyway! And it's always handy to have some around the house, especially if you're a somewhat-techy guy that loves tinkering with computers :)
Thanks 😀
