[SOLVED] I need help asap
Apr 22, 2020
5
Okey were to start, I just upgraded my PC I got a new MOBO and CPU and I'm in trouble with windows I can't boot into it after I created a boot drive on my m.2 NVMe drive,
So I tried both m.2 slots same problem as soon as I create the windows boot drive and it restart and is about to load to windows the PC blue screens and when it turns on again its stuck in a loop of unexpected restart press ok to restart.
It happens with both my m.2 drives and both my 240gb ssd's and yes I only have one m.2 in the PC when creating the boot drive and nothing else :/
So I have tried a lot of things I have been trying to fix this for the past 24 hours, but no progress
So now I need your help I don't know what to do.
If you need more info please comment and just ask.
CPU: ryzen 9 3950x
MOBO: Asus TUF gaming x570-plus (wi-fi)
Ram: 32gb from corsair
GPU: 2080 ti strix from Asus
Psu: gigabyte 1000w sumo
Storage: 1x Samsung 970 evo plus 500gb(main one) 1x Samsung 970 evo plus 250gb 2x corsair force LE 240gb
Sorry for bad English, from Iceland
While windows was installing I got a blue screen and "BUGCODE_NDIS_Driver". I can't boot into windows. I have an Asus Tuf Gaming plus wifi x570 motherboard with a ryzen 3950x. After the blue screen appears I am given the standard "the computer restarted unexpectedly..." message while the Asus TUF logo is in the background.
I have tried everything or at least I thought so,
To fix it I went to bios and disabled the wifi and bluetooth and everything worked like a charm I'm posting this here so for who ever googles the problem can hopefully see this because I know I was not the only one with this problem.
Are you getting any error codes with the BSODs?
What RAM is that, specifically?
Worth trying with only a single module installed and see if you get further into the installation process.
Give me a sec I'm going to do it again to get the code then I'll try with one stick and let you know what ram
