Hello,
I am building a new work PC and seem to have a power issue. Whenever I boot the system, all the components turn on, but I get nothing on my TV (using it as a test monitor). The light on my chassis blinks very fast a few seconds after I power on which is what is telling me I have some kind of power issue. Initially, I forgot to plug in the CPU power to the PSU, but when I would try to power on in that circumstance, I would not get the flashing light on my chassis. After I fixed that problem, by plugging in the 8-pin, I am getting the power issue.
By the way, it seems like the 4 + 4 pin that came with my PSU doesn't fit the CPU power slot on the motherboard perfectly in terms of the right sequence of squares/semi-circles. The one that just says 4 does, but the one that says 4+ does not. Specifically, on the motherboard, the slot for the 4+ has two square plugs and two semi-circle plugs, but the 4+ connector has all four semi-circles. The one that is just labeled 4 correctly has two squares, two semi-circles diagonal from each other. The plug where the 4+ would go is a mirror image on the motherboard, but not with the connector that came with my PSU. Could this have something to do with it?
Here are my parts:
Can anyone provide suggestions?
Here are my parts:
