[SOLVED] I need Help First PC Build
aniruddha_datta
Commendable
Jan 22, 2019
17
This is my First PC Build
CPU:- i5 9400F
Mobo:-MSI B360M Pro VH
Ram:- G.Skill TridentZ 8Gb
GPU:- GTX 1660 6GB GDDR5
PSU:- Corsair 450Watt
I am really worried with the CPU ,MOBO and the RAM i don't have any way to update the Bios once i have the PC so i need a Good MOBO under 100$ that supports 9gen CPUs without Bios Update. I also wanna Use the G.Skill TridentZ ram and i wanna know if it supports the Mobo. Can you guys suggest me a Good Affordable Mobo for i5 9400F.
the B360 boards will need a bios update to work with 9th gen. Though, some sellers actually provide a service where they can update the mobo for you before sending it to you (which they do in my country for just €10,- and they will install the CPU aswell + test it).
