I need help on overclocking...
I see...
Try your luck, then. What's your CPU, anyway?
Chances are that you won't need to go that far.
Think about it: setting your FSB@400 and your multiplier@9, you'll get 3.6Ghz on a E8400, or 20% increase over stock speed.
Not that good, but not that bad.
Your systems runs stock @8x333, or 2,66Ghz.
If I am not mistaken, with careful adjustments in volts, cooling etc. theoretically you could get to 3.6Ghz (9x400Mhz), or 35%.
Please, just don't go OCing. Read a tutorial first.
There is one very good here, at tom's.
Good luck
