I need help, please. Low budget!
SaintCharlie
61
Okay, I have alot of questions...
First off, my budget tops goes into 325 English pounds, though I would rather be paying 280.
Would it be best just to get a prebuilt pc? Or for my budget should I build my own?
I will be trying to run games like Minecraft and borderlands, as well as maybe battlefield 3 on playable specs.
Answer this question please, and I will carry on.
Next, I will need the specs and just general advice if I am to build my own, I am what is called a noob.
UPDATE:
Okay so a combination of everything led me to this part list I made :)
http://uk.pcpartpicker.com/user/SaintCharlie/saved/1kse
Are you sure? Good enough to run dirt 3 and borderlands 2? This will be used corley for gaming
Why did you even bother replying to this?
And this could run stuff at a playable rate? Honestly, I am literally walking into this blind. Haha I am way out of my depth...
Thanks so much, I have a load more questions and I know this is a big ask but do you think you could help me and advise me throughout this purchase. Thanks!
Thanks, could you look at the website too? I found 2 more that might be good, I dont know myself xD
http://www.freshtechsolutions.co.uk/custom-built-computers/mars-b-amd-fx-quad-core-3-6ghz-desktop-gaming-pc-1tb-8gb-ddr3-ati-6670-2gb.html
http://www.freshtechsolutions.co.uk/syclone-3-3ghz-intel-core-i3-3225-500gb-4gb-ddr3-1600mhz-hd-gaming-pc-computer.html
Thanks!
Thanks man, I am getting kind of mixed up about this whole thing. I want a pc for 300-380 that can play skyrim, dirt 3, battlefield 3, all on ultra or high. I dont mind if it is prebuilt or hombuilt.
If anyone else has any suggestions please tell me.
