I did my first build, later I got an extra sata cable and I tried to add it on, clone everything over to make it my boot device, and at first it did work. Then I tried to add the HDD back in, and I couldnt get it to boot. After that no matter what I did, it would not boot.
I came to the point where I was just gonna try to reinstall windows. It won't let me. I tried using windows reset option to erase everything and reinstall it. It wouldn't let me. I tried using it's advance configurations to fix it, everything basically told me to try another option, none of which worked because they said the same thing.
I need help wiping this PC, or getting booted up again so I can start over clean.
I have nothing important on it yet, I don't care if I lose everything I had so far.
I do have access to a laptop if I need to download anything from that.
I really appreciate any help.
