jinqty Distinguished Jun 23, 2010 36 0 18,530 Aug 2, 2010 #1 i desperately need help on removing the cover of a Galaxy geforce 9600GT because it wont fit into my bros motherboard without removing the cover...
hang-the-9 Titan Mar 25, 2010 60,387 1,081 152,940 Aug 2, 2010 #2 The cover is probably needed for cooling it properly. If you manage to get the cover off, you may need to underclock the card. Upvote 0 Downvote
S shadow187 Splendid Sep 16, 2009 4,103 0 23,160 Aug 2, 2010 #3 The cover's used for ventilation. Otherwise it'll dump the heat into your case. Upvote 0 Downvote
