I need help with a connector for a Keyboard
Palladini
17
I have put a new ASUS P8P67 Pro Motherboard in Dell XPS case, and it has one issue I so need to fix. I run two Keyboards on my Computer, a regular Keyboard and a Video Editing Keyboard. The regular Keyboard uses USB, but my Video Editing Keyboard uses a PS/2 keyboard/mouse port, the round one. Now the ASUS Motherboard has no mouse or Keyboard ports on the back of the board. So what I need is a connector to plug the PS/2 keyboard/mouse port into a USB port. Does such a device exist?
Yes as USAFRet and alexoiu mentioned it is exist and available in the market and you can easily purchase it from the retail computer store but beware if you're using this USB to Ps2 adapter for your video editing keyboard only then its okay but if you're purchasing it for your regular keyboard such as for gaming purposes then what I would recommend don't buy because with this adapter you won't be able to use w,a,s,d or areo keys of your keyboard finely as for example with normal Usb keyboard plugged in USB port or with Ps2 keyboard plugged in Ps2 port because I had used it.
uzamitprofessional - I am hooking up two keyboards, one above the other, the bottom one on a slide out tray. I will use the top one for every day use, and the slide out will be my Video Editing Keyboard, only used when I have one of my two Video editing programs running.
why he won't be able to use WASD keys with that adapter? pulses are similar on each key, and assuming the adapter is defective none of the keys would work
