Question I need help with Deep Learning on AMD RX 7600 ?
lucifer251297
17
I have an AMD RX 7600. Thing is, I'm relatively new to the whole deep learning scene, and I'd really appreciate some guidance from the community, especially if you've tackled deep learning on an AMD GPU before. Specifically, I'm planning to use PyTorch for my research. If any of you folks have experience with running deep learning tasks on an AMD GPU please guide me.
No (full disclosure) deep learning experience.
However, as a general observation a closer look at your planning is necessary.
What are the hardware and software requirements for running PyTorch /Python?
Overall, as I understand it all, the GPU is only part of the requirements.
FYI:
https://thegeeksdiary.com/2023/03/2...-support-on-windows-11-a-comprehensive-guide/
Look for other similar links and consider the options with respect to both your environment and research project.
Your experience and results are likely to be disappointing (at best) if the supporting system is unable to perform as required.
